Hydraulic Problem Hyundai HLF30c-5
Maybe someone can help with some information on this problem: No hydraulic operation at all. It sounds like out of fluid/howling/grinding??? But the level is fine. Looking down at the pump, I can see the pump drive shaft at the end of the crankshaft. there is what appears to be a coupler or drive plate attached to the crank pulley. There are some rubber bushings and bolts holding it together. From what I can see, the pump shaft is barely turning while the engine is running. My question is ; should the pump be turning at 1:1 ratio with the crankshaft? There is some rusty orange dust on the coupler. Do these things wear out? What is the name for that part?
Any insight would be appreciated.
  • Posted 18 Sep 2013 13:25
  • By earl
  • joined 18 Sep'13 - 3 messages
I'm no Hyundai expert but many forklifts use that type of drive on the pump. It's called a pump coupler and fits onto the splined shaft of the pump. It should turn at the same rate as the crankshaft. I think that spline is worn out in the coupler.
  • Posted 18 Sep 2013 20:21
edition #1243 - 14 August 2025
In this week’s Forkliftaction News , we look at more financial reports with one major producer recording a “significant” decline in Q2 bookings to report an operating loss of USD8.5 million, while another had a strong quarter “despite increased trade tensions and a challenging geopolitical landscape”... Continue reading
Ottumwa, IA, United States
St. Louis, MO, United States
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
