HOW TO RESET TIMING BELT HOURS ON TOYOTA
Does anyone know how to reset the timing belt hours Toyota 8FD35U. The unit does have Multifunction Display (DX). No information on this is in the service manual. The Belt hours are located in 6/6 of the I/O engine display but we don't know how to reset the belt hours. (We did Replace the Belt)
  • Posted 17 Aug 2021 00:21
  • By CaseyW
  • joined 21 Jun'13 - 4 messages
CaseyW
Old ones have a 3 pin connector from Fusebox to display 10-20 cm from the fuse box connect all 3 together instead of the matching fuse removal then:
When there is a matching fuse (STD lever vehicle)
NOTICE:
After removing the matching fuse, turning the ignition key switch ON causes an issue.
An error (error code 41-1) is displayed and stored in the SAS/OPS controller, for which care must be taken.
First, turn the ignition key on (or start the engine)
Step 2 Remove the matching fuse.
The hour meter shows "PASS_", and the wrench lamp is on.
The password display appears when it turns on.
Step 3 While shifting the tilt lever to backward tilt for more
than 5 seconds, returning the lever and tilt ****
switch after pressing the switch for more than 2 sec-
onds will indicate "1-dIAG" on the hour meter.
newer ones with short electronic levers you can reset it in the display.
by holding button 2-4 till beep then 3 again 3 2-4 until beep then go to:
? Even when there is no matching fuse, engine and display ECU information can be deleted.
? Refer to the multi-function display.
Step 1 Turn the ignition key switch ON (engine stop).
Step 2 Display the mask menu on the multi-function display
or multi-function display DX.
Step 3 Keep pressing the fork automatic leveling switch for
more than 2 seconds to display the matching menu.
NOTICE:
? Only "SET5-" displays with matching fuse.
? Indicated only when CAN communication ab-
normalities (AD-1 or AD-7) occur.
Step 4 Keep pressing the fork automatic leveling switch for
more than 2 seconds to delete the information.
0 indication: deleting the information is completed.
(Wrench light will be flashing)
Step 5 Turn the ignition key switch OFF.
good luck
  • Posted 20 Nov 2024 03:13
  • By sudormrf
  • joined 20 Nov'24 - 2 messages
  • Belgium
you know how to clear timing belt lift on dash on a 2021 toyota ?
  • Posted 11 Jun 2024 00:47
  • By keith_m
  • joined 29 Jun'09 - 57 messages
keith@kmcequipment.com
Hello. Ask for Tryinlinux: You write "pull fuse 7.5" - what fuse ?
  • Posted 4 Jun 2024 20:41
  • By kor1
  • joined 19 Dec'18 - 8 messages
  • Poland
Hi I know how is solve.
Take messages me on telegram to send pictures how to clear timing belt error
+989395094590
  • Posted 1 Mar 2024 08:59
  • By Afshin
  • joined 29 Aug'23 - 34 messages
  • Iran, Islamic Republic Of
Hi
Can someone help me with the sequencing on the levers?
Much appreciated
[email address removed]
  • Posted 18 Dec 2023 20:35
  • By Peter_Hughes
  • joined 26 May'22 - 5 messages
  • Ireland
PD Lift Trucks
I see that "tryinlinux" got it covered
  • Posted 2 Nov 2023 00:22
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
I may be able to help with that if I have your email.
  • Posted 2 Nov 2023 00:20
  • By ErichO
Turn key on, pull fuse 7.5,hold tilt lever down for 5 seconds then push tilt button for 2 seconds, dash will say " pass". Go to 1-diag and pull lever down 2x, push tilt button 4x and dash will say set6, hold button until it says set6-d.
I know this is kind of a pain way to do it, and it took me a few times to get it to reset properly, but that is the sequence
  • Posted 2 Nov 2023 00:17
  • By Tryinlinux
  • joined 10 May'12 - 8 messages
We are having the same issue. Does anyone know the sequence of buttons to push to get to this menu?
Mike
  • Posted 20 Oct 2023 01:36
  • By Mike_Mayer
  • joined 7 Dec'21 - 2 messages
  • Illinois, United States
Mike Mayer
ROYPOW
Taylor THC500L
Elwell-Parker ESI500-36
ROYPOW
