How to clear a code.
Anyone know the secret to clearing codes on a CAT C3000?
The unit overheated due a bad water pump. I changed out the water pump and the temperature guage shows normal now but all the dash lights keep blinking and a code E-33 (overheat) is present. Does it go away after awhile?
Any tips would be great.
  • Posted 25 May 2017 11:29
  • By ricardo_g
  • joined 25 May'17 - 1 message
Hi, did you figure out how to clear the code? I need to do this myself and could use the tip?
  • Posted 15 Jun 2023 03:51
  • By jason_g
  • joined 18 Apr'11 - 31 messages
  • Illinois, United States
did you open the bleed screw on the top of the water pump housing when refilling the cooling system? could have air trapped in there causing water pump cavitation.
  • Posted 10 Aug 2017 22:42
  • By Bacon123
  • joined 25 Jul'17 - 10 messages
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
Alogotransiphobia is the fear of being caught on public transport without a book to read.
