Horn Honking
When you try to start my S40FTS forklift the horn starts honking. What causes this?
  • Posted 5 Jun 2018 05:39
  • By JohnnyAlamo
  • joined 5 Jun'18 - 5 messages
Replace the horn.
  • Posted 15 Nov 2018 03:50
  • By BREWSKI
Was the promblem ever fixed if so what was causing it I'm having the same promblem horn stays on all the time
  • Posted 15 Nov 2018 02:15
  • By Cricketboi
  • joined 15 Nov'18 - 1 message
  • Illinois, United States
Low battery will throw a fault code. You may have a horn that is about to fail. These horns are smart horns, they have three wires connected. There is positive and negative at the horn at all times. The VSM sends a signal for the horn to sound. We have had horns do the pulse beep when they get moisture in the connector at the horn. This problem seems to happen more with a low battery.
  • Posted 5 Jun 2018 22:15
  • By BREWSKI
I've seen this happen twice on a Yale and never figured it out. It's kind of scary. Thank goodness the operator knew how to shut it off because I didn't have a clue.
  • Posted 5 Jun 2018 08:15
  • Modified 5 Jun 2018 20:37 by poster
Update~
I got some charge on the battery and went out and started it, no honking.
Low battery warning? Never has done that before.
  • Posted 5 Jun 2018 07:21
  • By JohnnyAlamo
By the way, it's an intermittent honk, like a one second burst every 3 seconds
  • Posted 5 Jun 2018 07:04
  • By JohnnyAlamo
I also should point out, even after you turn the key back off, it keeps honking until you push the horn button on the steering wheel, then its like it resets.
  • Posted 5 Jun 2018 07:03
  • By JohnnyAlamo
It's ok on fuel, normally this one just gives you a light on the dash for low fuel.
No fault code, the battery was low and it wouldn't quite start. Normal for this forklift as it gets started and run for a few minutes and shut off before it has time to recharge from the start. I have a charger on it now.
  • Posted 5 Jun 2018 07:02
  • By JohnnyAlamo
What happens when it starts? The new trucks have low fuel level warning. Are there fault codes showing on the display?
  • Posted 5 Jun 2018 06:51
  • By BREWSKI
Crown SX3030TT4250
Enforcer FLBAXT25
Crown SX3030TT4250
Enforcer FLBAXT25
