Help with Error Codes - it drives but no mast activity
Howdy forum -
I have a TMG15-E, serial # 248-1313-9570KF. It's a 3k lb electric lift.
It drives fine, but the mast will not raise, lower, or side-shift.
When I turn on the ignition I see the mechanic idiot light and the error code -01.
Can anyone point me in the right direction?
Thanks Dave
  • Posted 19 Jan 2017 02:37
  • By BreweryDave
  • joined 19 Jan'17 - 1 message
  • Illinois, United States
01 indicates park brake on. If park brake is not on and 01 still displays check the brake switch adjustment or wiring. Assure your battery is fully charged and correct voltage. Confirm your hydraulic motor starts and if does not, check fuses for lift pump and lift switches are functioning on the hydraulic valves.
  • Posted 30 Jan 2017 11:24
  • By tom_p
  • Alberta, Canada
