Help to find VNA or turret truck with man down for lift height 13m
Hi, any idea which VNA or turret truack that have a lift height of minimum 13m with man work from bottom.
I manage to find only 1 type - Jungheinrich etx 515. I cant find any higher then this from most company website.
Anyone can advise me.
  • Posted 12 Dec 2011 21:34
  • By Goodie
  • joined 12 Dec'11 - 3 messages
  • Singapore, Singapore
Than to you the future operator has salted?
BT VCE150 will help you
  • Posted 25 Jan 2012 13:02
  • By Last
  • joined 25 Jan'12 - 17 messages
  • Siberian, Russian Federation
Hi Goodie,
Based on all the discussions, do agree that it is not a good idea to have a man-down truck for 13 meters. Usually, a person vision and judgement is good up to 6 meters.
And if you want order picking, then a man-up will be the best. Operator goes up to 13 meters, pick up the goods and then he can go to another location to pick other items.
PAPA is right Jungheinrich had not sell a single ETX515.
  • Posted 12 Jan 2012 22:44
  • By richard_y
  • joined 9 Feb'07 - 66 messages
hi,
Kindly also take into consideration of parts availability , as man down is not common in Singapore. And Jungheinrich have not sell a single ETX515 in the past 10 years in Singapore
  • Posted 7 Jan 2012 11:45
  • By PAPA
  • joined 21 Jun'11 - 4 messages
  • singapore, Singapore
BT Reflex RRE can be had with mast lift height of 12.5 metres.
TLC system on the mast means its quick enough to reach max lift height.
As for VNA, BT VCE 150 can be had with a 14.8 metre lift height, its a man up truck.
  • Posted 6 Jan 2012 08:26
  • Modified 6 Jan 2012 08:29 by poster
  • By Forkingabout
  • england, United Kingdom
Hi all, thanks for the feedback. I will talk to my lecturer and if can change to order picking for 13m height will be good.
  • Posted 6 Jan 2012 02:53
  • By Goodie
There are quite a few reach trucks manufactured today that lift to 12M that require a stacking aisle greater than 3M. Many of these are being replaced with articulated man down machines that lift to 12M and that operate in aisles of approx 2.1M. These are working with better performance results than reach trucks because of their reduced aisle size, greater lifting capacity, high performance lift and lower speeds and the ability to work indoors and out.
  • Posted 6 Jan 2012 01:35
  • By edcampjr
  • joined 6 Jan'12 - 2 messages
  • Virginia, United States
BT launched there VR Veflex man down replacement last year based on the RRE Reflex.
New one is called the Vector R series
They only go up to 11 metres lift height though.
Nothing wrong with man down if it's specced correctly.
  • Posted 5 Jan 2012 22:52
  • By Forkingabout
You might struggle to get another two manufactors. Man down VNA are a thing of the past. These are low volume production now and built to old designs. The world will not miss them when the last is phased out.
At 13m iit is a bit crazy to be doing it all from ground level.
  • Posted 5 Jan 2012 21:02
  • By WhatName
  • joined 29 Oct'10 - 3 messages
  • Ayrshire, United Kingdom
Hi
It is not a good idea to use man-down VNA at such lifting height.
You may save money on the truck price, but may spend more in operation as it is not as efficient as man-up VNA at such height.
Even with camera system, it don't really provide much help.
Man-up VNA is the only solution.
  • Posted 23 Dec 2011 14:02
  • By TonyAsia
  • joined 3 Jun'11 - 1 message
save a lot of grief. man-up is your only answer. most companies will quote for a 13 mtr vna
  • Posted 22 Dec 2011 05:25
  • By kevin_k
I hope it has some kind of camera system on the forks as 13+ meters with the man on the ground is just asking for the racking to be knocked down sooner or later.
Highest we do at BT for man down is 11 metres.
  • Posted 21 Dec 2011 02:45
  • By Forkingabout
Hi, for my project and I manage to find 1 type. Jungheinrich etx 515 only. I need 3 to compare and stuck cos I unable to find other which suit this criteria. Asking if anyone have any idea of this.
  • Posted 14 Dec 2011 01:23
  • By Goodie
13M Lift and man down!!!!!
Why would you want such a combination?
  • Posted 13 Dec 2011 23:51
  • By Normandy
  • joined 28 Sep'06 - 186 messages
  • Co. Cork, Ireland
UN Forklift FD20-35FJM3
Taylor TT300
USD98,500
