HELP Need Clutch Disc size info
Clutch Disc size specs needed.....
I am needing to have the clutch disc relined in my old 1970 yale
I would like to get in a new Clutch Disc and have it in hand so as to be able to do the R&R over a weekend and not have the truck down for a week or more, and apart and in the way, as would be the case if I just take out the old Disc and send it off....
Truck info:
Model
G83P-040-5WT074
Serial # P183595
This is an "Oil Spray Clutch" or "Wet Clutch" setup.
The Yale part number for the Disc from the vintage parts manual is:
5158774-00
The info the rebuilder needs is the Disc DIAMETER, NUMBER OF SPLINES and INPUT SHAFT DIAMETER.
Any help much appreciated!
dan k
  • Posted 10 Jan 2013 02:04
  • By dkmc
  • joined 18 Oct'09 - 48 messages
Yes- H & R clutch is very good- have used them myself on occasion. Good luck
  • Posted 11 Jan 2013 07:33
  • By bbforks
Yes, YALE was of no help, too old a lift.
I found a re-builder in PA that did some research, and
they determined that it is a 12 inch disc, but two possible
input shaft diameters.
They are sending two discs, one of each size, and I will send
back the 'wrong' one with my old core.
Price is reasonable.
Very helpful folks...at H&R Clutch, Bensalem,PA
877 639 7150
  • Posted 11 Jan 2013 06:35
  • Modified 11 Jan 2013 06:37 by poster
  • By dkmc
Have you tried getting new clutch from an aftermarket source? I'm not sure anyone is going to have the information you need
  • Posted 11 Jan 2013 06:05
  • By bbforks
ROYPOW
Terberg YT222
Aichi SR10C1SM
