Have a question
Thanks in advance for your replies
Ran out of fuel, re-filled the tank, then the forklift will not start again, All I did was refill the propane tank.
Checked that fuel is getting to the system, connected properly...
  • Posted 1 Nov 2022 11:23
  • By Rick_McCoy
  • joined 1 Nov'22 - 2 messages
Rick
Thanks for your reply, already checked, that isn't the problem.
  • Posted 2 Nov 2022 01:18
  • By Rick_McCoy
Rick
Some times when you remove the tank there is a rubber ring that should be in the end of the tank it falls into the brass rego valve and when you change the tank it does not hit the pin to allow gas to come out of the tank check to see that the ring is not in the rego valve.
  • Posted 1 Nov 2022 12:56
  • By Scott_
Scott
Morooka MFD20
Manitou MH25-4
Morooka MFD20
Manitou MH25-4
