hard steering
have a hard steering issue the customer ran the hyd fluid level low enough to cause the fluid to burn and smoke. So far the orbital and steer cylinder seals have been replaced and the steer pressure adjusted to 850 psi not sure what the spec is for that? We are looking for the location of a priority valve but can not find one the main control valve on this unit has two adjustments main and steer relief. The dealer says it doesn't have a priority valve? any ideas? s/n is A809N10488X thanks
  • Posted 1 Feb 2017 04:12
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
anyone have a hydraulic schematic and parts page for the steering they can share please?
  • Posted 8 Feb 2017 05:45
  • By cownd
Thank you guys I'm heading out with one of my tech's this morning to sort this out. I'll post our findings
  • Posted 2 Feb 2017 00:57
  • By cownd
Steering flow control is in the inlet section of the control valve. 850 is the proper pressure for the steering.
  • Posted 2 Feb 2017 00:30
  • By BREWSKI
Can you follow the pressure line to the orbitrol back to see where it goes? If it goes to the control valve, that's where it is.
  • Posted 1 Feb 2017 10:52
Briefs United States
