H8.0ft will not start
Hi guys, got a h8.0FT6 with Kubota v3800t engine. It will eventually start with some easy start in the air intake, but will not idle. Briggs diagnosed blocked injectors, took them out and tested fine. All pressures as expected when it runs, but it will not start without easy start and accelerator needs to be to the floor to keep it going. I've recently stripped out the EGR valve as it's showing as stuck open at 12%. Valve was very coked up but cleaned up nicely, replaced it but still the same problem, could be the motorised controller which has failed, but would this stop the engine from starting?
  • Posted 9 Nov 2024 07:56
  • By EHUKLTD
  • joined 9 Nov'24 - 2 messages
  • United Kingdom
E,
First remove fuel filters and check for contamination. Make sure there is no water. Check the fuel pump inlet and lines to see if there is a screen that could be blocked. The Kubota engine does not like any foreign materials in the fuel system. How many hours on the lift? When you checked the fuel injectors, did you remove the common rail? If so, was there any contamination in it? When installing the injectors back, were they installed in the correct cylinder they came out of?
  • Posted 12 Nov 2024 00:02
  • By Fishmech
  • Virginia, United States
Tampa Florida, United States
TCM FHD105Z
Terberg RT223
VETTER Forks, Inc.
May CapEx Index falls Washington, DC, United States
VETTER Forks, Inc.
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
