Gopher 212
Having a problem with the platform slamming down. Only does it intermitently. Any Ideas?
  • Posted 2 Nov 2005 10:51
  • By JFwrench
  • joined 2 Nov'05 - 2 messages
Proportioning valve in manifold can intermittently cause problem. Might be sticking or debris in valve. When the lowering valve opens and the prop valve is not ramped to proper position you will have fast lowering even if you are choosing slow lowering.
  • Posted 22 Feb 2008 14:27
  • By carl_v
  • joined 12 Oct'07 - 76 messages
Hmm, short in lower button circuit, short in wiring harness to activate load hold solenoid valve , I would go with the short in the wiring to switch or defective switch.
My 2cents worth!
  • Posted 9 Jun 2007 12:32
  • By MtnMan
  • joined 9 Jun'07 - 8 messages
  • Alabama, United States
We work on anything and sometimes we fix something!
Michel Denis Michel Denis
