Glow-plug indicator
Indicator is on but glow-plags are OK, rele is OK, thermostatic switch is OK..
What else can be wrong??
thanks
regards
  • Posted 7 Sep 2014 02:01
  • By TANTADRUJ
  • joined 13 Oct'13 - 104 messages
  • ljubljana, Slovenia
Showing items 1 - 18 of 18 results.
What cable do you need to conect Path finder to Particle filter (reset)??
  • Posted 30 Sep 2014 04:05
  • By borut_veliki
  • joined 14 Dec'13 - 56 messages
  • novo mesto, Slovenia
Yes, it exist. you were wright. It's the vw cord 300 365 2503 for diesel and the vw cord 300 365 2504 for LPG.
I got it all the time but newer use it.....forgot about it.....
thanks
regards
  • Posted 18 Sep 2014 09:11
  • By TANTADRUJ
It connects in the same place as the standard pathfinder cable. It enables you to connect with cam/crank sensors, fuel injector pump timing settings etc.
Trust me, this does exist!
  • Posted 16 Sep 2014 15:01
  • By little_forker
  • joined 31 Jul'11 - 82 messages
And where is that engine controler connector??? There is only extra Particle filter connector and that is all!!
  • Posted 16 Sep 2014 00:17
  • By TANTADRUJ
There is one cable for connecting to traction/hydraulics/steering/display then additional cables for connecting to the engine controller.
  • Posted 15 Sep 2014 16:08
  • By little_forker
There is just one type of cables for LPG and Diesel for Pathfinder. You are totally cnfused.
  • Posted 15 Sep 2014 07:13
  • By TANTADRUJ
You will need to contact Linde for either a part number for the cable, but it will probably be easier and cheaper for you to get a linde engineer to come out. I don't have a part number for the cable (I don't work with them anymore!) but I know they have different cables for LPG and Diesel engines.
  • Posted 15 Sep 2014 06:46
  • By little_forker
yep little_forker i see that
the EDC flashes the glow plug indicator if a stage 2 fault is detected.
so yep, he will need pathfinder or whatever program DiagRA-CE is to get a detailed view on whats happening.
  • Posted 15 Sep 2014 00:34
Can you give me link to this cable? And what can be wrong with angine?
  • Posted 14 Sep 2014 17:24
  • By TANTADRUJ
Glow plug relay light staying on = engine fault. This module has an additional controller for the engine and needs a special cable to connect to it using pathfinder. You cannot connect to it using standard pathfinder cables.
  • Posted 14 Sep 2014 17:20
  • By little_forker
......Indicator is on but glow-plags are OK, rele is OK, thermostatic switch is OK....
  • Posted 11 Sep 2014 03:29
  • By TANTADRUJ
glow plug relay stuck closed?
  • Posted 11 Sep 2014 03:15
what do you have in mind??
  • Posted 11 Sep 2014 02:27
  • By TANTADRUJ
Do you have the correct cable for connecting with the engine?
  • Posted 11 Sep 2014 02:24
  • By little_forker
what foult?? no error is shoven. i have pathfinder.....
  • Posted 11 Sep 2014 00:38
  • By TANTADRUJ
This can be an engine fault indicator, have you got access to pathfinder?
  • Posted 10 Sep 2014 22:15
  • By little_forker
h2x392u02887
  • Posted 9 Sep 2014 06:19
  • By TANTADRUJ
Serial number?
  • Posted 9 Sep 2014 05:50
  • By little_forker
Toyota 8FGU25
Flesherton, Ontario, Canada
Terberg RT403
August 1-3, 2025 - Coimbatore, India
September 18, 2025 - Blair Athol, South Australia, Australia
November 04-05, 2025 - Houston, TX, United States
Simon Manasseh Simon Manasseh
VP business development for Europe, Noblelift Intelligent Equipment Co
Regional business manager, Doosan Bobcat Material Handling
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
