Fuse fu5 keeps blowing
Has anybody else encountered this problem fu5 keeps blowing? Originally a 5 amp fuse but has since been replaced with a 10 amp. works for a part shift then blows and no lift/lwer fwd/rev or display. Can't get it to do it when I'm there. Unit has 300 hrs on it wtf!
  • Posted 28 Feb 2016 01:07
  • By troy_m
A-Lift Services -- safe -reliable -affordable
Looking at the wiring diagram, first thought would be to change the fuel level sensor (LPG) which is directly fed from FU5. Swop to another machine if available? If that doesn't cure it then its most likely a wiring issue, maybe a wire rubbed through & grounding on the chassis somewhere. I would think an internal fault on Access 1 causing a 10A fuse to blow intermittently is very unlikely.
One suggestion is to replace FU5 with a mini-blade 5A auto-reset circuit breaker, this will reset when the fault clears and allow the customer to restart and continue using the machine until eventually the fault becomes more permanent. Not great but maybe better than constant visits.
  • Posted 28 Feb 2016 12:13
  • By techno_nz
  • Canterbury, New Zealand
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Daleville, IN, United States
Evansville, IN, United States
Uxbridge, Canada
St. Louis, MO, United States
US confidence index rises sharply Washington, DC, United States
CEO, MHEDA
Crown Equipment celebrates 80 years New Bremen, OH, United States
Uxbridge, Canada
CEO, MHEDA
