No drive
Good morning,
I have a Linde L14
The lift switch were bad, but I have to replace the whole board with the pot, now the lift works but not driving F/R.
I can hear the contactor clicking but no drive.
I ohms out the new pot and got the value,
Kindly, Any help advice?
Will be greatly appreciated
  • Posted 17 Jun 2025 22:25
  • By RamKhudan
  • joined 4 Feb'21 - 56 messages
  • Curacao
Ram
ramkhudan@gmail.com
Hi Frits_f,
Thank you very much!!!
I will work on this, and let you know.
I really appreciate everyone's help
Thanks to all of you ??
  • Posted 20 Jun 2025 23:03
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
the drive potentiometer should read 4,5 volt in neutral. correspinds with 2650 ohm. If not the relais click but slow pulsing.
You can adjust the potentiometer bij listening to the microswitches.
it works like this: the potentiometer is used by the drive controller to determine if it should drive and in which direction. The accelerator microswitches are there for safety: it is a check for the controller if the potentometer is correctly adjusted and not broken.
potentiometer is pin 6-7-8. switches are in parallel on pin 9-10
The clicking of the switches should be at the same time that the relay clicks. Symetrical forward and backward. If not, you should adjust the potentiometer.
After readjusting you have to recycle the key switch to clear the error.
  • Posted 19 Jun 2025 23:06
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
Hi Michel_V
Yes the motor is good
  • Posted 19 Jun 2025 22:43
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
Hi Michel_V
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
motor oke ?
  • Posted 19 Jun 2025 15:37
  • By michel_v
  • joined 8 Mar'08 - 1,039 messages
  • noord holland, Netherlands
Contactor and cable is good
Contactor clicking on f/r command but no drive when eccelerating
  • Posted 18 Jun 2025 22:51
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
contacktor oke?
cabel breuk naar motor
  • Posted 18 Jun 2025 15:50
  • By michel_v
The Serial number
W4X 372 U03910 year 2007
About the Throttle calibration no I don't,
How can I purchase the calibration tool?
Thank you so much
  • Posted 18 Jun 2025 05:30
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
Serial number please L14 means nothing it could be any generation.
1 question if you changed the tiller board did you calibrate the throttle potentiometer??
  • Posted 18 Jun 2025 05:16
  • Modified 18 Jun 2025 05:19 by poster
  • By lifter01
  • joined 4 Jul'09 - 465 messages
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
UN Forklift FD40T
UN Forklift FD50T-NJB3
Alogotransiphobia is the fear of being caught on public transport without a book to read.
