forks wont move
I have brought this just repaired the head gasket it has finger controls. now theres a light flashing on the dash and nothing will lift or move on the mast. can anyone help solve the problem is there a cut out switch hidden some where i may have bumped.has onyone an operators manual that may explain this
  • Posted 2 Jun 2012 17:44
  • Modified 2 Jun 2012 17:45 by poster
  • By woollamia
  • joined 2 Jun'12 - 6 messages
  • New South Wales, Australia
also the red light on the control box is constantly flashing every second has anyone the codes list or know what this is for this model it is a fg15 serial number starting f25a cheers
  • Posted 3 Jun 2012 09:30
  • By woollamia
Thanks for your reply Jplayer I should have mentioned the seat switch is bypassed and not connected
  • Posted 3 Jun 2012 07:26
  • By woollamia
make sure your seat switch circuit is hooked up
if the seat switch is not made the fork light on the dash will blink on and off and no hydraulic functions will work. The connector for this should be located somewhere on the right side rear engine compartment, usually around the hood hinge area. Just follow the wiring from the seat down to the harness , there should be a 3wire flat plug in the harness back there. :o)
good luck...
  • Posted 2 Jun 2012 21:41
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
