Forklift has no drive - Torque Converter?
Hi there, I have a Komatsu FD20-11 forklift which refuses to move. Got progressively worse to the point where it would move at initial start up, but stopped moving after a couple of minutes. I have checked the oil level in the torqflow transmission, cleaned the strainer and checked pressures at the test ports, the only port that gave an intermittent pressure reading was the reverse port, only 20 psi and it was not constant. The truck did try to move when I recorded the intermittent pressure. I have pulled the motor (Isuzu) as I want to check the oil pump. The torque converter refuses to come off the transmission input shaft, am I missing something? Does it just pull off, or is it retained somehow? Any assistance regarding checking the torque converter and torqflow oil pump would be appreciated, thanks
  • Posted 30 Aug 2020 08:54
  • By Griff
  • joined 30 Aug'20 - 3 messages
  • Lancashire, United Kingdom
Gman
Forgot to mention, I also checked the inching valve (left brake pedal) was coming all the way out and I visually inspected the clutch packs when cleaning the strainer, they looked to have friction material left. Thanks
  • Posted 30 Aug 2020 08:59
  • By Griff
Gman
UN Forklift FD20-35FJM3
Aichi RX07B
