FORK LIFTING ISSUE
My electric Yale raises and lower the forks. Only issue is that when the forks are up about 6 feet they jerk and jump up about 3 or 4-inches then will continue up smoothly. I have not been able to find out why they jump when they hit the second stage of the lift. Any ideas?
  • Posted 11 Mar 2023 09:00
  • By BRAD_ISHAM
  • joined 28 Dec'22 - 12 messages
  • Kansas, United States
ok, it lifts and lowers ok right?
only when it transitions from full free lift to start staging and the channels start telescoping in that first part of the channels starting to extend you get jerking?
i would pay attention to the rollers, look at how they track, when extended up past that point look in the channel tracks for any signs of rubbing. There would be witness marks if any unusual friction is taking place. If there are any thrust plates or wear strips they might be tight causing it to be tighter than usual and make it jump like that. If you want you can apply some grease to the channels and see if that improves it. It's not too hard to do, just get a painters tray and a roller with a long extension and just roll the grease on. Run it up and down a few times and see if the jumping stops.
Note: normally you wouldn't need to grease the channels and i don't recommend that because grease attracts dirt which in turn causes more wear so cleaning the grease out and applying new grease would have to be part of a pm routine if you started doing that.
With that being said i would pay attention to how tight those rollers are, how they are shimmed. Also measure the distance between the bottom rails of the channel compared to the top rails and see how close the rollers are on side thrust compared to the bottom. Like i said, if the top is narrower then the rollers might be binding from tight tolerances causing it to hang up and jump like that.
If you are not comfortable doing this then get a professional forklift tech to look at it.
But you can at least try the grease thing for now to see if that changes anything.
  • Posted 11 Mar 2023 11:44
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Crown WP302020
Airman ENCL045
July 9-10, 2025 - Birmingham, United Kingdom
Sourdough bread contains Lactobacillus reuteri, a probiotic bacteria. During pregnancy and breastfeeding, these bacteria can travel from the mother's colon to her breast tissue and be passed to the infant through breast milk. It offers various health benefits, including potential protection against breast cancer.
