FG20T-11
hi have a Komatsu approx 1990 FG20T-11 forklift in australia.
machine is in good condition, starts, runs,everything works, except no forward torque. gearbox definitely engages but even a slight incline with stop it moving. revving more does get slightly more torque
oil in gearbox is dark.
reverse seems to work ok, lots more torque.
im guessing clutch plates worn in forwards but ok in reverse? would a faulty torque converter fail in both directions?
anyone have access to workshop manual and service manual or parts lists for this model, as will be removing gearbox myself if thats what is required. happy to pay, just can't find them anywhere! can this be removed without removing front axle? i assume, engine out, then gearbox?
thanks for any help/ideas!
edit manual available for other model, any idea which models will be similar enough to use manual for gearbox?
  • Posted 30 Jan 2018 01:43
  • Modified 30 Jan 2018 01:44 by poster
  • By joshohm
  • joined 30 Jan'18 - 2 messages
thanks, looks reasonable hard to get axle/mast out, thought removing engine and unboltngngearbox from axle might have been the easy option, also leaves a rolling chassis so can still move it if i have to!
  • Posted 3 Feb 2018 15:38
  • By joshohm
I think the way you disassemble would be to remove the mast, then remove transmission and front axle differential as an assembly. Leave the motor in there, just support it with a come-a-long.
  • Posted 30 Jan 2018 06:45
Tusk 350CGH20
Autolift E180AT36B-D5-180
Tusk 350CGH20
Tusk 350CGH20
ROYPOW
