Faulty regulator?
Yale LP truck and the manifold and hoses freeze up when trying to start. Unit won't start at all. Any tips? Could it be the regulator?
  • Posted 27 Mar 2024 03:51
  • By James_Ortiz
  • joined 27 Mar'24 - 1 message
James ortiz
If the truck will not start when you first go on it than it is not a flow problem from a blockage that the regulator is not getting flow it is a bad regulator that is blowing to much gas pressure to the carb.if the truck starts and runs for about 5minutes and freezes up l would look for a restriction in the water lines to the regulator hope this helps
  • Posted 31 Mar 2024 09:55
  • By Scott_
Scott
hi you need to pressure test the water system you will probably find a leak loosing pressure creating air lock in the system if not the regulator is faulty unit wont start with frozen reg
  • Posted 29 Mar 2024 10:41
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Linde Material Handling
