FAULT CODES
Hi we have a stienboch-boss truck here that will not drive it is showing fault code 345 can any body help me on this thanks it has a bosch lt controller
  • Posted 12 Jun 2009 21:21
  • By corky
  • joined 14 May'09 - 9 messages
  • cork, Ireland
we all need a little help
Hi,
you must be wrong the WA 15 Mk II Series has no LT 200 Controllers there are 3 Atlas Copco Controllers (White / sometimes Black Boxes) Error Code 345 Means the Initiator on the Loadwheelbrake Ventil does not make an Cyclus. So check it when you turn on the Lift let someone push the Brake Button in the Cabin and watch for the LED on the Initiator ist must be Off then the Switch is pushed ot goes on then for 0,5 sec off an then it goes On and stays on as long as the Brake Button is pushed. The after ca. 10 Sec it will turn off until you push the Button again.
Mfg
Sven
  • Posted 15 Jun 2009 01:47
  • By turbocabrio
  • joined 31 Aug'08 - 16 messages
  • Bayern, Germany
Briefs United States
SMV (Konecranes) 4632CC5
Nagano NUZ090D
