Hyster E 2.50XM:
fault codes
hi , fault code showing on my hyster e2.50xm, -145 and -148 anyone any ideas please.
peter
  • Posted 21 Jun 2016 23:45
  • Discussion started by peterb
  • lancashire, United Kingdom
The power steering brushes are worn.
  • Posted 22 Aug 2018 22:57
  • Reply by BREWSKI
Hi I have a fault code -93 on Hyster J2.50XM, can anyone please help.
Thanks.
  • Posted 22 Aug 2018 18:29
  • Modified 22 Aug 2018 18:45 by poster
  • Reply by arnie
  • western cape, South Africa
arnold@rafforklift.co.za
Have you checked the resistance in the Can loop? With this many fault codes it is likely you have a comm problem. You should see 60 ohms across pin a and pin b in the diagnostic connector. make sure the battery is unplugged and the key switch off.
  • Posted 15 Sep 2016 01:07
  • Reply by BREWSKI
i have a yale reach truck model NR035EANL36TE119
serial D815N02488H
my turck is trowing 9 codes all at once
#238 trac control fault
#247 remote comm error
#241 steer comm error
#242 handle comm err
#238 tilt coil open
#323 str pos err
#52 str encoder fault
#345 traction high volt
#16 steer high volt
i checked all my wires an checked volts to battery
  • Posted 14 Sep 2016 23:30
  • Reply by bryan_d
STATUS CODE
-145
DESCRIPTION
1 REC did not turn on properly.
MEMORY Yes
RECALL
CONTROL
TYPE Pump
Figure 1
SYMPTOM
Forward or reverse contactor will open and close, then
open and then can only be closed by opening and closing
the key switch.
POSSIBLE CAUSE
Defective 2 REC circuit.
* Check for shorted 2 REC.
* Check for shorted 2 REC snubber (22 REC).
Defective 1 REC circuit.
* Check for open circuit or loose connections between
1REC and PZ8. (white/blue wire)
* Check for open circuit or loose connection between
1REC (3 REC snubber) and PZ9. (blue wire)
Defective 1 REC.
* Intermittent or open 1 REC gate. Field test may or may
not show defect. Replace 1 REC after above checks,
show no problem found.
  • Posted 16 Aug 2016 21:50
  • Reply by ken1234
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
