Fault codes
I was wondering if anyone had a fault code list for a Toyota 7HBW23. I have two of these machines and it seems every other day I am chasing down a code.
  • Posted 19 Apr 2011 21:50
  • By Jesse
  • joined 19 Apr'11 - 1 message
J Lane
The Richmond Group
Maintenance Supervisor
Possible Causes and Corrective Actions
* Master Control ON/OFF switch activated
* Low voltage to power amplifier (especially while lifting or driving) due to over-current or short-circuit.
* Try a known-good battery
* PTC R1 missing, faulty, or tripped (very high resistance, due to excessive current while main contactor is open; should automatically recover).
* Carefully check to see if R1 is hot (tripped). If so, unplug battery and allow it to cool. Locate low impedance path that tripped R1 and correct.
* Wire #24 at 0V due to J5 not connected, blown fuse, or bad wiring. * Check for 24 V at J5-16
* Short or open circuit in CAN wiring, or electrical noise in CAN wiring due to bad connection or outside interference, both at power ON.
* Check CAN wiring
* Try operating truck in different environment
* Bad power amplifier
I would check the battery state of charge and make sure it is good and not dropping voltage......
  • Posted 21 Jun 2013 06:34
  • By kevin_t
Our Toyota 7hbw23 jack is pulling up a c 28 error, can any1 help me with what this is?
  • Posted 21 Jun 2013 02:10
  • By Mtroy23
  • joined 21 Jun'13 - 1 message
  • Maryland, United States
Thanks for all your help.As we had just put new batteries in we checked main contactor and had one so we tried it this indeed cured the problem
  • Posted 8 Jul 2012 10:28
  • By gary_r
  • joined 14 Dec'10 - 18 messages
  • British Columbia, Canada
I just ran into a code E115 problem and it turned out to be the main contactor. The code is not listed in the manual but it does come up.
  • Posted 7 Jul 2012 17:58
  • By sleepywheel
  • joined 18 Jan'08 - 77 messages
E115 is usually the main contactor is not functioning properly. I know they have an updated one because of the the problems they were having. I would make sure that the batteries are good first, they can cause a lot of issues with these trucks if they are weak.
  • Posted 5 Jul 2012 01:08
  • By rogeriwt
Has it got an electric steering motor on it?
On a BT machine ( which this is based on ) E115 on the small stuff is steer servo start up error.
  • Posted 4 Jul 2012 21:00
  • By Forkingabout
  • england, United Kingdom
error code which unit is showing is e115 however that code does not exist from all info we have can you help
  • Posted 4 Jul 2012 13:08
  • By gary_r
The code we are rec is e115 which supposedly does not exist. We have the curtis handset but this code does not exist still looking for any info available
  • Posted 4 Jul 2012 13:07
  • By gary_r
I wonder if you have a particular question we might help with. Some code you are seeing that we might be able to decipher for you?
You were correct to contact the manufacturer's dealer rep to acquire the manual, it seems odd that it would take so long.
ALSO
Are your trucks equipped with Curtis controllers, if so, Curtis instruments has manuals for the controllers (which should include codes and wire schematics) on their web- site.
Search for "Curtis Instruments USA" should get you the code listing for these units.
AND
In my not all that humble opinion, if I had more than 2 units with Curtis controllers to care for, I would sure be wanting to have a Curtis handset. it makes troubleshooting and setup so much easier that it is well worth the $
  • Posted 30 Jun 2012 23:01
  • Modified 30 Jun 2012 23:09 by poster
Hi
What error codes is it throwing up?
It has a BT Rolatruc tiller head on & a Sepex Curtis unit so its most likely based on a 24 volt dc BT Rolatruc electrical system.
  • Posted 30 Jun 2012 23:00
  • By Forkingabout
Sorry I cannot help you however I was wondering if you ever got a list of codes have ordered manual and the dealer says will take 5-6 weeks can you help me.Thanking you in advance if so
GARY
  • Posted 30 Jun 2012 03:25
  • By gary_r
ROYPOW
edition #1271 - 5 March 2026
In this week’s Forkliftaction News, Hyster-Yale has reported a 13% reduction in revenues for 2025 while KION Group reports a revenue dip of 1.8%, with macro-economic and geo-political tensions named as partly accountable for the falls. Both companies, however, remain positive about the outlook for 2026... Continue reading
UN Forklift FBRP15NQZ2
SMV (Konecranes) 12-1200B
Ran Makavy Ran Makavy
Director, Cyngn
Vice president people Americas, TVH Americas
Vice president of sales, Eneroc USA
Chief executive officer, Eneroc USA
