Fault Code
i am experiencing a fault code FLT 30069 Pre charge on the main display. there is no alarm number corresponding to this code being displayed. looking for advice on where to start troubleshooting. fork truck is not operational with this code being displayed.
  • Posted 17 May 2019 10:26
  • By kenneth_w
  • joined 17 May'19 - 1 message
  • Newfoundland and Labrador, Canada
DTC 30069 (Cont) Precharge
CAUSE A - CONTROLLER WIRING FAULT PROCEDURE OR ACTION: 1. Measure voltage between the traction controller B(+) terminal and B(-). Is precharge voltage same as battery voltage? YES: Proceed to Cause B. NO: Check for external loads or shorts on the B(+) circuit and phase cables. Refer to the Basic Electrical Troubleshootingsection and perform Voltage Checks. CAUSE B - FAULTY TRACTION CONTROLLER PROCEDURE OR ACTION: 1. If no faults are found, replace controller. Make sure to indicate the DTC code(s) on the warranty claim to include an accurate problem description leading to controller replacement
  • Posted 17 May 2019 22:07
  • By BREWSKI
Toyota 02-8FD25
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Sue Tomic Sue Tomic
