fault code ER 137
hi guys im looking for information on this machine i have lift and steering but no drive.machine starts up ok but when drive is selected fault code ER 137 flashes on the dash.
any help would be great thanks
  • Posted 14 Mar 2013 06:52
  • By Mag1
  • joined 24 Feb'06 - 25 messages
  • CO DUBLIN, Ireland
Meaning: Driver release driver: VZA controls driver but driver checkback signal missing.
Effect: Driving switched off (drive, Mikropils, brake)
Possible cause: driver on SK-VZA defective.
Measure: status analysis MZ-100, visually inspect SK-VZA, replace if necessaary. Before starting check the protection circuit of the drive contactors.
VZA: is the driver compartment processing unit
Also check the microfuses. The cards in the VZA and VZK are interchageable, so you might be able to identify a faulty card by swapping. There are some measures to be taken before swapping. If you need these email me.
  • Posted 7 Dec 2013 00:12
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
