Fault Code 97-3 and fault 524227-3
Hello, i have this Fault code Hyster 155FT serial J006V03385H
Fault 97-3
Fault 524227-3
need help.
  • Posted 25 Oct 2016 03:49
  • Modified 25 Oct 2016 03:50 by poster
  • By jean_b
  • joined 25 Oct'16 - 5 messages
  • Panama, Panama
Many Thanks, i will check BREWSKI.
  • Posted 26 Oct 2016 07:06
  • By jean_b
  • Panama, Panama
97-3 is water in fuel sensor circuit, voltage above normal, or shorted to source.
DTC 524227-3 -( Manual Hydraulic Enable Valve Coil OORH) A. COIL DRIVER OUTPUT SHORTED TO BATTERY
B. COIL DRIVER OUTPUT OPEN CIRCUIT
C. COIL DRIVER RETURN OPEN CIRCUIT
D. RELAY/COIL OPEN CIRCUIT
E. FUNCTIONAL FAILURE IN CONTROLLER.
  • Posted 25 Oct 2016 08:26
  • By BREWSKI
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
