Fault code 157-18
Hey has anyone ran into the fault code 167-18 on a 2010 hyster forklift if so, what were some of the things you did to figure out the issue?
  • Posted 12 Sep 2016 22:14
  • By DGrand
  • joined 12 Sep'16 - 3 messages
We are having the same code. What did you end up doing to fix the issue?
  • Posted 28 Dec 2016 13:16
  • By Rodey
  • joined 16 Oct'12 - 21 messages
  • Michigan, United States
Thanks for the info I will check it out asap.
  • Posted 13 Sep 2016 17:19
  • By DGrand
157-18, injector metering pressure rail #1 low. Reading is valid but below normal.
  • Posted 13 Sep 2016 02:48
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
sorry that was a typo...the correct one is... 157-18... I think I may have figured something out because I noticed it was running a little hot so I will be checking the cooling system tomorrow.
  • Posted 13 Sep 2016 02:39
  • Modified 13 Sep 2016 02:40 by poster
  • By DGrand
Are you sure this is the code you are getting? I cannot find this code. If it is 168-18, this is low battery voltage.
  • Posted 12 Sep 2016 22:47
  • By BREWSKI
UN Forklift FBRS15KQZ2
Toyota 8FD45
