fault 245 pathfinder Linde R14 AC 2005
Hi , i have a 245 fault in a Linde AC 115 serial truck, line contactor not closed and book flash on dash. battery full and oke.
i hope you can help me
  • Posted 1 May 2014 14:45
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Did you get this sorted we have the same problem
  • Posted 10 Feb 2025 02:47
  • By paul_haggar
  • joined 11 Feb'21 - 4 messages
  • Northamptonshire, United Kingdom
weird...
thanks for the update.
  • Posted 4 May 2014 06:55
  • By frits_f
  • joined 19 Dec'09 - 318 messages
  • utrechte, Netherlands
hi , i have replace LAC module , same problem. second step i replace charge resistor with the k2 and k3 relay but no effect!! With a screw driver i have shortcut the contact k1 directly after start up with ignition and problem fixed.. truck works oke and i can set it off and on and all oke. I have no idea how and what give the problem
  • Posted 3 May 2014 02:25
  • By gc_d
Regards gc_d
oke thanks , i check this tomorrow and write as i find the problem
  • Posted 2 May 2014 04:49
  • By gc_d
Regards gc_d
I don't have experience with this particular error on this truck. But had similar errors on a 386 model.
The manuals say check the wiring: charging circuit, etc. Could be a bad battery / bad connection/dry cell (checked that? try with an other battery!).
But probably the capacitors in the LAC are bad; charging them takes too long. I once opened a power module and found some loose soldering of the capacitors.
Oh, and I had a truck on which a working light was connected after the line contactor: it didn't start when the working lights were on.
  • Posted 2 May 2014 04:37
  • By frits_f
Hi frits , i have seen this so any idea how fix this ? or only fix it with replace LAC module?
  • Posted 1 May 2014 23:32
  • By gc_d
Regards gc_d
If it is a traction error : 245: LAC cannot reach 40V during charging.
You have a problem with the charging circuit that charges the capacitors directly after starting up.
  • Posted 1 May 2014 18:09
  • By frits_f
MAXAM Tire, Inc.
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
Jim Tompkins Jim Tompkins
Sales operations, Heli
MAXAM Tire, Inc.
