failure tilt function Linde E14-02
hello i have a linde e14-02 when using tilt function it sometimes cuts out, only on tilt, reset with the key everything is fine again.
can someone help me with this? the truck is built in 1999
  • Posted 8 May 2021 23:20
  • By Forklift123
  • joined 11 Feb'21 - 38 messages
  • Netherlands
swap solenoid tilt for shift , then you can check also swap problem to shift, if yes solenoid problem. If not it is joystick problem , joysticks sure oke or new ,problem in hydraulic control card.
  • Posted 18 May 2021 03:08
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Hi
Only carried out with truck doctor
Or using a handheld device
  • Posted 17 May 2021 19:09
  • Modified 17 May 2021 19:10 by poster
  • By Lindetechnz
  • joined 28 Apr'21 - 58 messages
  • New Zealand
Lindetechnz
Good morning,
Can you tell me how the calibration procedure works?
Or is this only possible via software?
  • Posted 17 May 2021 19:07
  • By Forklift123
  • Netherlands
Mechanic of Forklifts, Aerial platforms & telehandlers in the Netherlands
HELLO ,
If joystick replace for new , check if correct calibration done.
You can have a problem in solenoid tilt valve , so check error number in software.
If not have software on pc , you can try swap the solenoid on valve block for the shift solenoid. First check wiring to solenoid of course...
  • Posted 15 May 2021 18:49
  • By tr_doctor
  • Netherlands
Regards
good afternoon, the serial number is: H2X335K04275
  • Posted 14 May 2021 21:11
  • By Forklift123
  • Netherlands
Hello, The joystick has already been replaced, this does not solve the malfunction. the values of the joystick are correct on the input of the computer.
  • Posted 14 May 2021 21:09
  • By Forklift123
  • Netherlands
You have a problem in joystick lever. Replace it for new.
  • Posted 11 May 2021 22:05
  • By tr_doctor
  • Netherlands
Regards
What's the serial number ?
  • Posted 10 May 2021 20:13
  • By Lindetechnz
  • New Zealand
Lindetechnz
Terberg RT403
Toyota 3FD100
Terberg RT403
Toyota 3FD100
