Event code 226
The forks goes up very slow and also it goes down very slow.
The lift pump motor rotates very slow on both directions.
the 3 phase cables from access 2 to pump motor heating up.
What could be the possible cause?
  • Posted 4 Feb 2021 07:17
  • Modified 9 Feb 2021 22:10 by poster
  • By RamKhudan
  • joined 4 Feb'21 - 56 messages
  • Curacao
Ram
ramkhudan@gmail.com
I checked cooling fan, the fan run good
I checked all the connections, all good
  • Posted 6 Feb 2021 06:16
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
I checked the battery condition
All are good, voltage are good under load
  • Posted 6 Feb 2021 06:11
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
Check battery condition, water level, and voltage under load
  • Posted 5 Feb 2021 06:41
  • By Triggs
the lift going up and down very slow
also the lift pump motor rotating very slow
the 3 cables to the pump getting hot
access 2 heats up and the code 226 sets, after lifting the fork for a minute or 2
  • Posted 5 Feb 2021 03:46
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
could be cooling fan not running, or loose connections building heat. you can check fan operation in accessories menu
  • Posted 5 Feb 2021 03:19
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Terberg RT223
UN Forklift FBR25NQC3
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
