Event Code 176
Hi, I have a Crown SC5200 unit that originally had error code 305, we changed Access 3 and now shows code 176. The manual does not have any code or any bulletin. Any help will be greatly appreciated it.
Thank you. Carolina
  • Posted 18 Apr 2024 04:45
  • By UPC8532
  • joined 11 Nov'16 - 8 messages
Hi. Have same code. Did you figure out at end?
  • Posted 13 Feb 2025 08:03
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
First I would go into the service menu on the original access 1 module and go into features 20.1 and turn off the battery restraint feature. It could be this lift does not have a battery retainer switch and updating the software caused it to be reenabled.
  • Posted 18 Apr 2024 05:03
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 228 messages
  • Wisconsin, United States
Hi, correct. We replaced the access 3 due to code 305 and new software was installed to the whole truck. After doing this code 176 shows up as well as the wrench. We tried switching module 1 from the SC to a FC but the screen is black. Maybe module 1 is bad? Thanks.
  • Posted 18 Apr 2024 04:57
  • By UPC8532
When you installed the new access 3 did you flash software to the whole truck? New modules do not come with software pre-loaded. All the modules also need to have the same software version so even if the new module came with software it might be the wrong one. Typically if a crown throws a code that does not exist it means one of the modules isnt configured correctly. Seems like you replaced the access 3 due to code 305?
  • Posted 18 Apr 2024 04:52
Since February 2016, it has been against the law for grocery stores and supermarkets in France to throw away unsold or expired food which is still edible. Instead, it must be donated to food banks or composted.
edition #1272 - 12 March 2026
In this week’s Forkliftaction News , we report on the three inaugural CEOs who will manage the new materials handling entity of Toyota Automated Logistics when it launches on April 1... Continue reading
SMV (Konecranes) 4531CC5
UN Forklift FD35T
New Haven, Ct, United States
