Event Code 112
Currently getting an event code 112. I have replaced every wire between the distribution board and access 2 as well as each wire from the distribution board to access 1. Access 2 is new and access 1 is new. Still getting the code. Getting.96VDC between CAN H and CAN L. Can anyone help!!
  • Posted 3 Nov 2017 06:04
  • By LifeSpike
  • joined 3 Nov'17 - 5 messages
  • Washington, United States
When you replaced the access modules did you have to do anything with the software? Something could have been turned off when you flashed the software and it is now not talking.
  • Posted 5 Nov 2017 22:32
  • By popeye
Access2 pin 18 to pin 19 should be 120 ohm
  • Posted 5 Nov 2017 11:56
  • By Ifixit
Ok, we checked both access 1 and 3 on the specified pins and they read at 120 ohm.
  • Posted 5 Nov 2017 11:46
  • By LifeSpike
Unplug the connectors from Access1 and Access3. Pin 18 to pin 19 on Access1 (not the wire) should be 120 ohm. And on Access3, pin 17 to pin 19 should be 120 ohm. If either is lower than 115 ohm or greater than 125 ohm......replace that Access module. Sometimes I forget, even though a part is new...doesn't mean it's good.
  • Posted 5 Nov 2017 09:52
  • Modified 5 Nov 2017 09:54 by poster
  • By Ifixit
Sorry, when they are plugged in we are getting 59.6 ohms. When the can line is unplugged for the test we are getting 120. Event code 112 still happening.
  • Posted 5 Nov 2017 05:02
  • By LifeSpike
If you got 120 ohms on the CAN line with all the modules plugged in then you have a problem. It should only be 60 ohms
  • Posted 4 Nov 2017 21:13
  • By popeye
Yes it checked good I think they were 120 ohms
  • Posted 4 Nov 2017 01:04
  • By LifeSpike
Did you check the can terminating resister
  • Posted 3 Nov 2017 15:10
  • By Ifixit
Michel Denis Michel Denis
