error main contactor
hello everybody,i'm have a problem in nichiyu FB30P AC. when key on everything good., but when press drive or hydraulic or sterring will appear error A1=main contactor
  • Posted 15 Nov 2013 05:03
  • By duga_m
  • joined 3 Aug'12 - 15 messages
  • yogyakarta, Indonesia
workhard!!
dougamaulana@yahoo.com
Showing items 1 - 20 of 22 results.
salam kenal
  • Posted 21 Dec 2015 04:00
  • By pedro_apituley1
  • joined 30 Oct'15 - 15 messages
  • jakarta selatan, Indonesia
pedro.gpmforklift@gmail.com
Can anyone help the error of Nichiyu FBRAW18-63B-550MCS?
It has error A6:FET9-REVERSE and can go forward but cannot go backward. The service manual of this model is also helpful. Thank you.
  • Posted 14 Jan 2015 14:05
  • By Hanabi
  • joined 4 Mar'11 - 18 messages
  • Tokyo, Japan
infinitetrade@yahoo.com
Klo error IGBT b-11.output yang keluar dari mosfet di MPU ad yg gk beres.. Kemungkinan repair modulny belum selesao
  • Posted 20 Aug 2014 21:00
  • By duga_m
hai rudi
jika igbt rusak pasti ada yang gak beres
coba cek driver igbt nya pasti salah satu icnya ada yang rusak
foto profil saya itu juga driver igbt
  • Posted 20 Aug 2014 06:57
  • By ario_alif
  • joined 12 Nov'13 - 36 messages
  • east java, Indonesia
Mas ario mau tanya nih.,
Klo error codenya B11- IGBT travel kira2 apanya ya?
IGBT travel baru
Modul habis direpair tapi tetap muncul B11
Tolong kasih infonya ya makasih.
  • Posted 27 Jan 2014 15:32
  • By rudy_j
  • joined 27 Jan'14 - 1 message
  • kepulauan riau, Indonesia
ga sampean butuh battery tel aye dong....
aku stock 72 volt mas
  • Posted 21 Jan 2014 00:02
  • By ismail_keong
  • joined 21 Jan'14 - 1 message
  • DKI JAKARTA, Indonesia
Best Regards
Ismail Temannya Kasino
sudah beli aza battery baru mas duga ,, heheee
  • Posted 21 Jan 2014 00:00
  • By mardi_a
  • joined 20 Jan'14 - 1 message
  • DKI Jakarta, Indonesia
hello Duga, I'm glad you could solve the problem. I'm must say that a battery related problem isn't always the fault of the forklift manufacturer. Having as you mentioned mushrooms on the battery connectors can be blamed of bad maintenance or a bad sealing on the connectors.
Kind regards
marc b
  • Posted 13 Jan 2014 00:10
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
marc b,you're right i founds some problem in the AC series NYK forklift several time battery conector a bad cause mushrooms accu. so it is a weakness in NYK AC series either in reachtruck or counterbalance
  • Posted 12 Jan 2014 15:10
  • By duga_m
workhard!!
Hello Duga, have you seen the fuses and the voltage at the fuses and main contactor? we had several time that a battery cell was broken or a battery connector had a bad connection.
Kind regards
marcb
  • Posted 19 Nov 2013 02:14
  • By marc_b
  • ANTWERP, Belgium
email saya :douga [email address removed]
  • Posted 16 Nov 2013 11:17
  • By duga_m
workhard!!
hello ario_alif:
my email :[email address removed].
soalnya kalo di repair untuk mosfetnya tidak ketemu persamanya.kalo pak ario suka repair boleh.tolong sms ke no saya:085716238370,nanti saya coba repair
untuk IGBT merek mitsubishi,saya biasanya nyari di YUN ELECTRONIK,lokasi di Glodok,.coba cari di google ada web nya kok.,thanks
  • Posted 16 Nov 2013 11:15
  • Modified 16 Nov 2013 11:16 by poster
  • By duga_m
workhard!!
coba kamu merger semua motor, apa kamu udah cek semua controlnya
  • Posted 16 Nov 2013 11:14
  • By ario_alif
arioalif10@gmail.com
hello marc b,thaks for information., but voltage battery normally=72V and for voltage 48V normally,so when first ON main contactor function,however when hydraulic or drive or sterring be played it would appear error A1:Main Contactor., if restart key everything OK,be played hydraulic,drive or sterring then problem A1:main contactor appear.
  • Posted 16 Nov 2013 11:10
  • By duga_m
workhard!!
email u mana duga_m
  • Posted 16 Nov 2013 11:05
  • By ario_alif
coba direpair. saya kalo nichiyu tak repair semua. type igbt nya apa kok ketemu 1,2jt
  • Posted 16 Nov 2013 11:03
  • By ario_alif
hello ario alif :
ketika on normal saat pedal gas,atau hydraulic or sterring di tekan maka akan muncul error A1 ;main contactor.saat nyala pertama kontaktor berfungsi.,
apakah punya modul nichiyunya dan berapa harganya.
untuk IGBT sudah cek ke jakarta di YUN ELECTRONIK,biasanya ada harganya bisa 1.2jt Rp.
  • Posted 16 Nov 2013 10:57
  • By duga_m
workhard!!
I ask your email marc_b
I forget later I saw in the factory, which I remember model : FBR20
IGBT Three phase his type: FM600TU-07A
  • Posted 15 Nov 2013 07:23
  • By ario_alif
Hello Ario, from witch model of Nichiyu is this IGBT and function? do you have the original part number by any change?
kind regards
marc b
  • Posted 15 Nov 2013 07:04
  • By marc_b
  • ANTWERP, Belgium
hello marc_b
I saw on the forum if you forkliftaction and senior profiles in Nichiyu.
I often fix Nichiyu mpu board and display.
I would like a reply FM600tu-07a IGBT in Indonesia is expensive.
Approximately how many there prices?
thank you
  • Posted 15 Nov 2013 06:31
  • By ario_alif
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
