Error Code
Please I need Help For The Issue
Machine Have Error Code 676 - 4
And Sometimes Show Hydraulic Interlock Return To Neutral
Can I Get Some Help I will Appreciate.
  • Posted 23 Jun 2015 18:11
  • By KASBATIOUN
  • joined 3 Jun'15 - 12 messages
  • lagos, Nigeria
Pdm Fault means fault With the Power distribution module wich are located in the engine compartment where the fuses and relays are located.
  • Posted 19 May 2017 06:22
  • By JAFFA
  • joined 19 May'17 - 2 messages
  • nedre eiker, Norway
Thank You BREWSKI For You Help, Can I know Which Relay Need To Check ???
And what Mean PDM Fault ??
Thanks For Support
  • Posted 25 Jun 2015 00:37
  • By KASBATIOUN
  • lagos, Nigeria
676-4 is a glow plug relay voltage low fault. If you are getting a return to neutral you need to be sure your hydraulic levers are not activated at key on.
  • Posted 23 Jun 2015 22:32
  • By BREWSKI
UN Forklift FD30-35T
UN Forklift FBR25NQC3
