Error code T208
Hello there,
I am having problem with Linde H60D-03 (396 series). It works normal but when I add some gas the error T208 is displayed and the forklift dies.
On pathfinder it says:
Measured wheel speed inplausible (difference between calculated and measured wheel speed)
But I dont really know what it means. Is is some kind of wheel speed sensor?
  • Posted 5 Mar 2024 00:13
  • By Spitaldoo
  • joined 26 Nov'19 - 5 messages
  • Slovenia
Calibration of oil motor and HPV
  • Posted 6 Sep 2024 15:38
  • By michel_v
  • noord holland, Netherlands
I was searching it in program, but didn't find it, maybe you can give directions where i will find it?!
  • Posted 6 Sep 2024 06:15
  • By kalle_v
  • joined 15 Apr'13 - 26 messages
  • Brasserie, Latvia
kalle.vahk@mail.ee
try to relearn the speed sensor
  • Posted 5 Sep 2024 15:28
  • By michel_v
In and out show motors speed, but program is quite slow on refreshing. if monitoring and driving and error appears, on truck self braking time you still see motrs speed.
  • Posted 4 Sep 2024 17:49
  • By kalle_v
  • Brasserie, Latvia
kalle.vahk@mail.ee
Hello
I got same problem, changed speed sensor, nothing, then i change second sensor, also nothing! Any other solution? Oil was also coming out alot, other sensor housing was also ful of oil.
  • Posted 4 Sep 2024 17:46
  • By kalle_v
  • Brasserie, Latvia
kalle.vahk@mail.ee
look on phatfinder in and out puts
  • Posted 14 Mar 2024 17:40
  • By michel_v
I changed both sensors, but when you push the gas pedal to the max it stil shows the error.
  • Posted 14 Mar 2024 01:07
  • By Spitaldoo
  • Slovenia
look on in out puts in phatfinder tab oil motor I think you can see there whether it is left or right
  • Posted 8 Mar 2024 17:47
  • By michel_v
I'm lucky that I haven't broken the sensor yet
but when I look at the drawing, it could be that Ollie is a bit leaky
  • Posted 8 Mar 2024 17:30
  • By michel_v
I replaced the sensor, but I saw that there are two of them. The error is still displayed so I will try to change the other one.
Is it normal that there is hydraulic oil? When I changed the sensor the oil came out?
I don´t know much about 396 series, especially the 03 model
Thank you for your help
  • Posted 8 Mar 2024 02:08
  • By Spitaldoo
  • Slovenia
7917415597
sensor driving speed
  • Posted 6 Mar 2024 18:01
  • By michel_v
Toyota 3FD100
Crown RD572513TT6860R
Toyota 3FD100
