Error code no hydraulic operating
Error code on main screen is
PLUG d
Fault indicator lamp
And load screen flashing LEDs
A1 and A7 alternately A4 and A8
Book says defective link in the operation of the longitudinal stability limiter and warning device
Tried connections at battery and hydraulic ECU seam clean ect not sure where to go from here have no diagnostic tool to plug in
Any idea what next
Many thanks
Dave
  • Posted 13 Oct 2022 12:28
  • By David_Smith
  • joined 13 Oct'22 - 1 message
  • Queensland, Australia
Dave
It sounds like you have already done some troubleshooting on your own, which is a great start. Since you don't have a diagnostic tool to plug in, your options are somewhat limited, but there are a few things you can try.
First, check the operation of the longitudinal stability limiter and warning device, as the book suggests. This could involve checking the wiring connections, sensors, and other components associated with the system. If you're not sure where to start, you could try looking for a service manual or other documentation that provides more information on the system.
Another possibility is to see if there are any error codes stored in the vehicle's computer system. Even without a diagnostic tool, it may be possible to retrieve codes by using a jumper wire or other tool to bridge certain connectors in the diagnostic port. Again, a service manual or other documentation may be helpful in identifying the correct connectors to bridge.
If you're still stuck, it may be time to consider taking the vehicle to a professional mechanic or dealer who can use diagnostic tools to identify the source of the problem. While this may involve some additional expense, it could ultimately save you time and frustration in the long run.
Overall, troubleshooting complex electrical and hydraulic systems can be challenging, but with some patience and persistence, you may be able to narrow down the source of the problem and get your vehicle back on the road.
  • Posted 10 Mar 2023 17:13
  • By heathwoodau
  • joined 9 Mar'23 - 2 messages
  • New South Wales, Australia
Hydraulic Service and Repairs in Australia - https://www.heathwoodhydraulics.com.au/
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Ncn 85TH
Ncn 85TH 2014
