error code L224. Linde R14-1120. year 2015
Hi... all my friends.
please help, for the trouble I'm facing.
for the hydraulic function everything is dead or does not work, when the joystick is moved elevator error code L224 and if it is reached reach error code L225.
what I have done is check the pump motor, speed sensor, sensor temperature, cable and all ok. maybe there are friends who have had this problem we can share information. thank you
  • Posted 22 Jul 2019 20:36
  • Discussion started by FNGLOBAL
  • south sumatra, Indonesia
grow and develop together
L 224
Fault description
Pump motor does not start/is stuck (number of revolutions < 50 rpm) although lifting joystick 2B1 is moved.
Note: See SI403/17
Conditions of occurence
Result
Indicator lamp: interlock warning !
Possible causes
Collision while lifting
Steps to eliminate the fault
225 Pump motor does not start/is stuck (number of revolutions < 50 rpm) although reach carriage joystick 2B2 is moved.
Note: See SI403/17
  • Posted 18 Sep 2019 03:24
  • Reply by michel_v
  • noord holland, Netherlands
Sir
Good day
Model; R20hd-1
Nr, H21120Fo1851
Year: 2015
Sorry for 2014 wrong year model
Thank you and god bless
Noel Reyes
  • Posted 17 Sep 2019 06:06
  • Reply by noel_reyes
  • Philippines
Wrench
115 1120 type what is serial nr
  • Posted 17 Sep 2019 05:31
  • Reply by michel_v
R20hd-1 sir have error L224 and L 225
  • Posted 16 Sep 2019 20:27
  • Philippines
Wrench
whits model
  • Posted 16 Sep 2019 05:06
  • Reply by michel_v
same senaryo
Hi... all
please please help
brand; linde reach truck
model; R20hd-1
year ;2014
  • Posted 14 Sep 2019 23:39
  • Philippines
terima kasih, semoga saya dapat menyelesaikan masalah ini
  • Posted 29 Jul 2019 13:35
  • Reply by FNGLOBAL
I've sent you the manual. But ultimately you need Linde service program to re -learn all parameters. I put an A2 controller in one, needed to calibrate everything before it would move. Some Linde's with intermittent issues were fixed by simply calibrating accelerator or height
Good luck with your battle on the R14!
  • Posted 27 Jul 2019 23:04
  • Reply by EasiTek
124 Pump-motor does not speed up when Lift-/Reach-Joystick operated.
Note: See SI403/17
L 124
Fault description
Note: See SI403/17
Result
Indicator lamp: turtle slow speed
Disable all joystick inputs except lower
Possible causes
Collision while lifting (Resettable with neutral joystick)
  • Posted 27 Jul 2019 15:44
  • Reply by michel_v
[email address removed]
  • Posted 26 Jul 2019 12:12
  • Reply by FNGLOBAL
Oh I feel you're pain. I feel that Linde lifts were built by Germans to get back at us for losing the war! I have an R16 reach manual from 2015, and can send to you. put your email in profile, I will send to you.
Good luck!
  • Posted 24 Jul 2019 09:37
  • Modified 24 Jul 2019 09:37 by poster
  • Reply by EasiTek
Hangcha CBD15
China
USD1,600
JLG 600AJ
JLG 600AJ 2012
Flesherton, Ontario, Canada
Flexi&reg; By Narrow Aisle Limited
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
