ERROR CODE H9-1 Unload valve solenoid open-circuit abnormality
THIS REFERS TO THE A UNIT WITH MINI LEVERS I DON'T HAVE THAT AND IT IS SET CORRECTLY IN THE OPTIONS ANY OTHER SUGGESTIONS THE TILT WILL NOT WORK BUT EVERYTHING ELSE DOES. THERE IS A SPLITTER SOLENOID IN LINE WITH THE TILT RETURN HOSING I DON'T SEE IT ON THE WIRE SCHEMATIC.
  • Posted 26 Mar 2022 05:23
  • By JOE_RESKE
  • joined 26 Mar'22 - 2 messages
  • Michigan, United States
THE HYDRAULIC MOTOR DOES COME ON BUT THE TILT IS NOT WORKING I HAVE BYPASSED THE SPLITTER VALVE AND THE TILT WORKS CORRECTLY.
  • Posted 30 Mar 2022 22:07
  • By JOE_RESKE
Does it have a tilt sensor, if so try to calibrate it, I had a similar problem, the sensor was out of calibration because the mast pivot bushes were broken up and missing.
  • Posted 30 Mar 2022 19:31
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
Just a quick question. Is your display battery good? Does the time/date hold when disconnected to charge truck battery.
So when you say the tilt doesn't work, no change in pump motor activity forward or back?
  • Posted 30 Mar 2022 09:23
  • Modified 30 Mar 2022 09:28 by poster
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
Maxlion MTF30-45-2WD
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
