Error code FH
The service manual says that an error code FH is due to battery out of range. All cards are in good working order and battery is new. Can someone please help us out with this code. I have discharged the battery some so that it comes down from 38 volts as the reason for the code is battery voltage out of range.
  • Posted 18 Sep 2018 03:18
  • By andrew_v
  • joined 18 Sep'18 - 1 message
Fh = f'n hot battery. Overvoltage.
Usually comes when the battery is right off the charger.
I have had instances of vfc causing this. Rare for b+ sense wiring to bring this code up but it is possible.
  • Posted 30 Sep 2018 09:45
  • By stam
What's the model?
We had some issues with this a decade ago on swing reaches. Found turning operator lights on for a it would allow a start up.
You may need new firmware/flashware to reset the parameters.
  • Posted 30 Sep 2018 05:23
  • By Dunc
  • joined 30 Sep'18 - 3 messages
Not so, if it's at 36V static (Not being used) it needs to be charged.
Lead acid battery discharge is not a linear function, from nominal battery voltage (i.e. 36 volts) to zero. To put battery voltage versus charge state in perspective - a healthy, fully charged 12 volt lead acid battery will be 12.7 to 12.8 volts (high performance batteries even higher). At 11.9 volts, a 12 volt battery is effectively discharged. You can pull them lower than this (not much useable power), or if not charged they will continue to drop voltage, but this is where damage occurs. An 80% discharged battery (12 volt) measures about 12.0 volts. Multiply these numbers by 2, 3, or 4 for 24, 36 or 48 volt forklift batteries.
  • Posted 30 Sep 2018 05:22
  • By Dunc
What type of reach, model? 38 volts...charger may be bad too. Should have no more than 36 volts after charge.
  • Posted 25 Sep 2018 21:56
  • By EasiTek
