Error Code E67-1, and Clearing Toyota Codes
I am working on this Toyota 8FGU32, and it is displaying a E67-1 error code, I checked the mast sensor, and harness, they appear to working correctly, I disconnected the battery, cleaned up the terminals and posts, assuming this would be enough time to clear any codes, but the code is still present on the display, I tried the 5 cycles of the accelerator pedal, but still no luck.
There does not appear to be any ill effect to the code, other than being a nuisance code scrolling across the display.
Any thoughts, tips or suggestions?
  • Posted 14 Feb 2014 01:39
  • By Wajaxed
  • joined 16 Feb'10 - 23 messages
  • British Columbia, Canada
If it wasn't for human error and negligence, I would have nothing to do most days.
Stay safe
Ed
how did you solve this issue i have a unit having the same issue.
  • Posted 23 Nov 2022 02:18
  • By ANDREW_WORLEY
  • joined 20 Dec'19 - 6 messages
  • Oklahoma, United States
Yep, that is a faulty cpu board.
You can sent it to TVH if possible, they can fix it for a good price ore sent you a used one.
  • Posted 8 Mar 2020 03:42
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
hi john,i am suspecting to have a faulty cpu because i got the cpu on the forklift which is giving me errors then i plugged the same cpu on the forklift which is working but the same error(E67-1) still popped up,can it be a faulty cpu?
  • Posted 8 Mar 2020 03:12
  • By matel
  • joined 7 Mar'20 - 4 messages
  • Zambia
67-1 is the lift height sensor, check the cable conection between mast and body, you can disconnect the sensor and see if any other error pops up. There are 3 wires. (normaly open and normaly closed)
You can,t clear the errorlog, when error is fixted the display will not show the error.
  • Posted 8 Mar 2020 02:05
  • By John50
  • Netherlands
To clear the errorlog, just disconnect the - side battery for a minute.
  • Posted 8 Mar 2020 01:59
  • By John50
  • Netherlands
i am also experiencing E67-1 on my toyota forklift FBEU15,how did you manage to clear out the error?
  • Posted 7 Mar 2020 02:05
  • By matel
  • Zambia
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Taylor TXB180S
TCM FD80Z7
TCM FD80Z7 1990
