Error code C57
An pallet jack Raymond model 8400 serial number 840-11-87320, mark the error code C57, this happens when accelerating to move and immediately put in slow motion mode. Can anyone help with the meaning of this code?
  • Posted 20 Aug 2015 10:56
  • By hector_v
  • joined 17 Nov'11 - 42 messages
  • Puebla, Mexico
Saludos
hectorvargasm@msn.com
For me every time it's a loose female spade on the male spade on the main contactor. The blue one with 2 wires.
Except for one, replacing the contactor solved it.
  • Posted 28 Oct 2025 09:42
  • By warp_shimatsu
  • joined 15 Mar'25 - 2 messages
I had a toyota 8 series jack which is identical to the Raymond with the same issue.ended up being a pinched wire behind the horn for the resistor coil for the brakes
  • Posted 6 Jan 2025 09:23
  • By roc109
  • joined 2 Nov'09 - 51 messages
pour les modèles 8210, voir fil sur le klaxon si il n'est pas débranché. ce qui peut occasionner le code C57
  • Posted 6 Jan 2024 00:57
  • By francois383
  • joined 12 May'22 - 2 messages
  • Quebec, Canada
Frank 383
Yes, those bushings are very important as brake switch goes on/off very fast and codes out truck. It makes truck cut out intermittently too, frustrating driver. I used to have that as cause in my old notes. Will add to other post.
  • Posted 2 Apr 2017 21:40
  • By EasiTek
Thank you for the tip, The handle bushes were worn out and the sensor moved out of position.
  • Posted 2 Apr 2017 02:09
  • By hector_v
  • Puebla, Mexico
Saludos
C57 is brake circuit. Check wires over motor, where the harness bends as you turn. Check splices for bad crimps
  • Posted 1 Apr 2017 23:30
  • By EasiTek
what our techs have found is the springs for the buttons in the control pop out of place not allowing the magnetic sensors to return to neutral. Also check the coast select actuator have seen those pop off sometimes at the handle return spring.
  • Posted 28 Mar 2017 03:22
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
Terberg RT223
Terberg RT403
Bolzoni SpA (Group HQ)
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
Terberg RT223
Terberg RT403
Andreas Schneider Andreas Schneider
Managing director sales & service, STILL
Executive vice president people & culture, Konecranes
Vice president of operations, Hangcha Forklift America
Senior solutions sales engineer, Numina Group
