Error code c-66
Hey everyone so yesterday I was using my pallet jack and it was raining it did get a little wet but not to bad. Today I'm using it and out of nowhere it stopped and wouldn't move. When I try and put the code to turn it on the green light doesn't even flashes when I press the numbers. Gives me a code c-66 and AC don't know what to do. And on the displays when I turn it on sometimes it says sorr maybe it means sorry??
  • Posted 21 Mar 2019 05:06
  • By Jerry
  • joined 21 Mar'19 - 3 messages
Code AC is for the charger is charging when you turn on key
Code c66 is brake coil driver open or shorted
Examine for short or open in brake coil wiring
Could be water shorting something
Code SRO Static return to off
Brake is not applied when truck is turned on. Handle is in the brake released range prior to the system being powered on
  • Posted 23 Apr 2019 04:11
  • By Captain
  • joined 23 Apr'19 - 2 messages
  • Alberta, Canada
