Error code 808-4
Hi, I hope you can help me ! I'm working on a Yale GLP040 and it has a constant error code of 808-4, any idea what this might be?
  • Posted 13 Feb 2018 09:30
  • By britain_w
  • joined 17 Jun'16 - 19 messages
  • Washington, United States
Mechanic
good deal,
yes i supposed if everything checked out ok then there is always that possibility that the controller itself may not be seeing the signal in that circuit for some internal reason.
controllers arent cheap though so hope that is actually what it is.
tblsht diagram says to check stop lamp output wire #788 (pin7) at vsm connector, if resistance is less than 0.5 ohms then repair short to ground in harness circuit, if no then replace the vsm.
  • Posted 20 Feb 2018 22:50
I ran thru the checks ,removed the assemblies and was told the controller was the problem, thanks
  • Posted 20 Feb 2018 14:55
  • By britain_w
oh yes, check your bulbs, if one burns out it will show an error
thx brewski :o)
  • Posted 20 Feb 2018 14:40
Stop lamp output low.
  • Posted 20 Feb 2018 00:17
  • By BREWSKI
what are the letters in the model number after the GLP040___?
  • Posted 13 Feb 2018 16:04
I'm sorry my mistake, when I got to the customer found code to be a 880-4
  • Posted 13 Feb 2018 10:27
  • By britain_w
Mechanic
Toyota 8FD45
Toyota 3FD100
Michel Denis Michel Denis
Toyota 8FD45
Toyota 3FD100
