error code 36
I have a Toyota stock picker model 6BPU15, Serial number 70517 that will stop lowering and show a code 36 in the display. Any ideas on what code 36 means?
  • Posted 17 Jul 2015 03:50
  • By lvscr
  • joined 24 Apr'14 - 41 messages
  • Idaho, United States
You probably already know. This is a lift pot malfunction code. You can try calibrating the handle and seeing if that helps or eliminates your problem. If you have to replace the pot, I believe Toyota is only offering the handle assembly, make sure you get the TSBulletin on installation.
  • Posted 25 Jul 2015 13:59
  • By Hero5
  • joined 17 May'14 - 56 messages
Take care of the customer
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
