Error code 31?
What is error code 31 mean on my 2EC30?
  • Posted 16 Oct 2013 00:29
  • By seth_c
  • joined 11 Oct'13 - 2 messages
  • Washington, United States
what was the fix ?
  • Posted 19 Sep 2019 11:19
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
I had a code 31 on a CAT forklift. The engine would not accelerate and the check engine light was on. It turned out to be a blown 15amp fuse.
  • Posted 31 Dec 2013 03:03
  • By TerryM
  • joined 31 Dec'13 - 1 message
on a microcommand system:
Display = 31: Pump armature transistor emitter fault (low, B terminal). No lift truck operation.
on EV100ZX there is no code 31 so you have to have the microcommand system.
you can go ahead and give serial number if you like but the code is still going to be the same.
  • Posted 16 Oct 2013 08:08
we will need the serial number to be sure we give you the most correct opinions as to your code.
  • Posted 16 Oct 2013 07:33
Mitsubishi FGE35AT
Maxlion FDR50
