Error code 2E Raymond forklift
Hi,
we have a problem with a raymond with a error code 2E.
What does that error code mean?
Thank you for your help
  • Posted 21 Jun 2013 01:50
  • By yoann_h
  • joined 21 Jun'13 - 13 messages
  • Quebec, Canada
Here the mains cards :
https://photos-1.dropbox.com/t/0/AAAcuzrAgLNNd-4eu71T6pKb0nIX46gRpmWg3NVDGFQxAA/12/62885776/jpeg/32x32/3/_/1/2/IMG051.jpg/O3JZj3Z5p-UYfEAVzkHeEfq_gXQ55QFic42AE4GCUP8?size=800x600
We change these cards with others from the same forklift model and we found the same error code.
so the error could it be from this card?
https://photos-6.dropbox.com/t/0/AADpGw_itb7hwtpEj0Q0Bh9U0ErJcMS3GUzc5oHeJ6lfdQ/12/62885776/jpeg/32x32/3/_/1/2/IMG052.jpg/TXliI0z9Dx5bLARnh6W_SMWoaRRrKWE9ehhLRXskkbw?size=800x600
  • Posted 23 Jul 2013 01:02
  • Modified 23 Jul 2013 01:13 by poster
  • By yoann_h
  • Quebec, Canada
Hello,
Thank you for your answer.
What is the VFC? Is it the one where the heat sensor is plug on it?
I found this picture online :
https://photos-3.dropbox.com/t/0/AAAMx48CvHf3rYx3KfGRuiTwrbbIYVl3RONi8E9Qzh4gGA/12/62885776/jpeg/32x32/3/_/1/2/009.jpg/sFCvVgfKUPZSHD3U2-wc36WT0QxH-J9BqOF0spTEzOY?size=800x600
Is it the one in the middle?
  • Posted 22 Jul 2013 22:27
  • Modified 23 Jul 2013 01:12 by poster
  • By yoann_h
  • Quebec, Canada
if everything else is ok then it is the vfc card.
  • Posted 21 Jul 2013 22:30
  • By stam
Hi,
Some news about our raymond : we checked the card and we didn't find any problem, we also interchange the motherboard with one from another forklift (without error code) and it doesn't work better. We still have this error code 2E...
- heat sensor checked and fine
- wire from heat sensor to board : fine
- we have 5v at the sensor connection pin
So I don't know what could be the problem... Any idea?
Thank you for your time and help ;-)
Yoann
  • Posted 18 Jul 2013 22:18
  • By yoann_h
  • Quebec, Canada
Thanks for your answers.
We checked the tension between the pins and we don't have the 5v...
We will extract the card and check for broken condensator or broken resistor...
I hope we will not have to replace the card...
  • Posted 2 Jul 2013 22:07
  • By yoann_h
  • Quebec, Canada
I wouldnt reccomend changing the firmware unless you must, f series codes with a new vfc would dictate if you need firmware or not. fyi: as new versions are released errors are often made in the programming side and sometimes cause a problem that is not repairable until a new version is released (dealers wont sell old firmware)
  • Posted 30 Jun 2013 22:24
  • By stam
If you do wind up replacing the vfc you may need to update the firmware as well.
I beleive your local Raymond dealer is G N Johnston Equipment.
  • Posted 29 Jun 2013 01:49
  • By EJ877
  • joined 25 Jun'13 - 4 messages
yes it could be a problem with a card.
with the battery disconnected, find plug on the system card marked JPS7, it should be an 18 pin connector that plugs directly into the system card (motherboard in control panel) check for resistance using pin 12 and pin 18. with the sensor plugged into the harness and the truck at room temperature you should read around 850 - 2000 ohms. if open circuit is found, check for resistance using the above pins to the sensor plug and correct any resistive wiring found.
if above is all ok. unplug sensor from harness. connect battery and turn truck on. use JPS7 again. have your meter leads back probing the plug. check for voltage at jps7-12 (b-) and jps7-18 (b+) should be 5 volts. if not the system card is at fault. if you do have 5 volts, your vfc card is bad (rectangle card screwed to the system card)
  • Posted 28 Jun 2013 21:15
  • By stam
My serial number is EZ-A-00-18446 and the model is FASI R45TT-M.
We've checked the voltage out of the sensor plug and get 0v.
Could it be a problem with the electronic card?
Thanks
  • Posted 27 Jun 2013 22:24
  • By yoann_h
  • Quebec, Canada
when the problem is corrected the code will go away, no way to erase the code, it will clear after the truck see's proper voltage from the sensor.
i am willing to assist you but to proceed further a model and serial number of your truck would be required.
  • Posted 27 Jun 2013 20:21
  • By stam
Hi,
We checked every wires sensors and we found several discontinuities in these wires.
We fixed that but we still have the 2E error message.
We also try to swap a new sensor from another raymond but the problem is still here
Do we have to reset the memory or do a button combination in order to erase this error message?
Thanks for your help
  • Posted 27 Jun 2013 05:38
  • By yoann_h
  • Quebec, Canada
Ok, we will check that. Thanks for your help ;-)
  • Posted 21 Jun 2013 22:06
  • By yoann_h
  • Quebec, Canada
2e - traction motor temperature out of range.
probaly a broken wire to the sensor.
  • Posted 21 Jun 2013 07:28
  • By stam
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
Neutron stars, the remnants of supernova explosions, have such extreme density that a tablespoonful of their material would weigh over 1 billion tons on Earth.
UN Forklift FBR25NQC3
Unicarriers FD80-2
Olathe, KS, United States
Dallas/Ft Worth, United States
