Error code 223
Help
With the battery disconnected am getting a voltage reading between the chasis and positive lead on the battery.Am also getting a voltage from negative lead of the battery and chasis when the battery is completely disconnected.
Lastly with the line contactor not closed am getting a voltage reading from the fuses.
  • Posted 24 Dec 2022 17:58
  • By George_Chikomwe
  • joined 23 Mar'22 - 6 messages
  • South Africa
Gc
this seems to be a common fault over time, it comes from the battery being voltage to frame.
as some machines have a sensor to frame check it must be as low as possible to remove the fault.
this comes with water spillage and over filling batteries.
ma worst case was full voltage to frame, easily seen by corrosion build up around battery and case.
the only way to reduce this is to remove the battery from the machine, take to workshop and steam clean between case and battery.
also sprinkle bicarbonate of soda over all the battery if acid is present you will see fizzing, if no fizzing then let battery dry and put on charge.
wait for a day then conduct voltage to frame check.
if it is still higher than 15volts to frame then continue the cleaning process.
my worst battery took three days to clear after which the forklift was back to full use.
Hope you find this helpful.
  • Posted 5 Jan 2023 16:32
  • By Alan_Reeves
  • joined 5 Jan'23 - 3 messages
  • Victoria, Australia
A Reeves
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
UN Forklift FGL25T
Terberg YT182
Jason Morgan Jason Morgan
director of aftermarket, Noblelift North America
sales manager of Texas, Taylor Machine Works
board advisor, Humanitarian Logistics Association
lead sales - Northern Europe, Camso Construction
