Error Code 202 displaying -Forklift is functioning fine
I have a Hyster J40ZT Serial # J160N03200E, That is Showing a code 202 after the initial start up sequence. Everything seems to be operational on the forklift, but the code has me concerned that I may have an issue developing. The manual only shows codes up to 99.
Any help would be appreciated
  • Posted 16 Mar 2020 12:58
  • By Cambox1
  • joined 16 Aug'16 - 18 messages
No one knows everything...ask for help before you have to pay for that mistake.
Do you know the password to get into the main menu so I can do some troubleshooting? It's probably still the factory set password but I'm not sure and wanted to try if someone knows the factory password.
  • Posted 1 Jul 2022 01:04
  • By BigAl73
  • joined 9 Aug'19 - 18 messages
Ilk baslatma sirasindan sonra 215 kodunu gösteren Hyster J40ZT Seri # arizayi nasil çözebiliriz birde 222 arizasi veriyor ayni makinada
Littoral translation from Turkish
Hyster J40ZT Serial # showing the code 215 after the first boot sequence # how can we solve the problem, it gives 222 error on the same machine
  • Posted 15 Nov 2021 20:36
  • By Cihan
  • joined 15 Nov'21 - 1 message
  • Turkey
Cihan
Thanks Swoop! I saw that for the Yale's and just was making sure. It is at a remote site and will check it out next week. Thank you sir!
  • Posted 17 Mar 2020 06:37
  • By Cambox1
code 202 is hydraulic oil low
check your oil level, top it off if needed
check your truck for leaks and repair them if need be
  • Posted 16 Mar 2020 23:45
