ERROR 628
Hi all , we have a Hyster H2.5XT A380B , 2017 , lpg 2.4L PSI engine , we have just the replaced the head gasket and upon trying to start we get code 628, this relates to fuel pump relay coil open ? as soon as we connect the battery the previously mentioned relay powers up , the engine turns over but we have no spark, we have checked over the wiring /connectors etc and everything seems ok , any help on this would greatly appreciated
  • Posted 1 Jun 2024 19:57
  • By PETER_B
  • joined 1 Jun'24 - 1 message
  • United Kingdom
Peter,
Lifts with the 2.4L PSI engine were known to have failed wire harness just before the coil connections start. You may have one or two wires that are cracked just before the connector. Good Luck.
  • Posted 11 Jun 2024 05:04
  • By Fishmech
  • Virginia, United States
Toyota 8FG25
Nagano NUL120-6
