Error 56
Since somebody changed the controller for the Joystick in the Armrest, Error 56 is coming up all the time. All the functions are working normally but the customer does not like to have an error in the display all the time. We checked so far the Joysticks, the wiring and the connectors to the controller. What else is bringing up this error? Serial Nr. of the Machine is ET18C52xxx.
  • Posted 28 Feb 2013 00:06
  • By stefan_g
  • joined 25 Feb'13 - 1 message
  • Bern, Switzerland
well stefan, if we had a complete serial number it might help more.
But....
after looking in the error code list, the 56 code is omitted, it jumps from F55 to F57. Both of these codes deal with the tilt solenoid operation be it either fwd or back tilt operation.
could be possible they installed the wrong controller?
most if not all of thier controllers have software revisions and if it is not the correct one it could cause this error.
if not then doublecheck the connections.
also it may need to be calibrated.
use the GSE tool and check the settings for hydraulic controls, the new controller may be set to the wrong settings. I believe you can use this tool to change the settings to what they should be.
  • Posted 28 Feb 2013 00:59
  • Modified 28 Feb 2013 01:01 by poster
Maxlion FD30
Manitou MH25-4
RAEDER-VOGEL
Maxlion FD30
Manitou MH25-4
