Erro code 676-4
Dear friends ,
please i need Help for error code 676-4 the forklift is not starting (truck is disable ) and giving another error code : 522762-4
thanks.
  • Posted 24 Jun 2015 17:32
  • By dib_k
  • joined 5 Nov'14 - 12 messages
  • lagos, Nigeria
Dib khanji
524240-3 Washer Pump Driver OORH.
676-4 - Glow Plug Relay Driver Output OORL
  • Posted 6 Apr 2018 22:26
  • By BREWSKI
Hi Brewski, Same truck as the bale clamp fault Hyster H3.0FT Diesel with mini-levers is showing 2 fault codes 1st one is 524240-3 and 2nd code is 676-4 The 2nd code came up when the screenwash bottle wiring was reconnected??? truck starts and runs fine. Also the Bale clamp is piped into the 4th mini-lever valve.
  • Posted 6 Apr 2018 19:14
  • By SMcG
  • joined 18 Feb'18 - 30 messages
  • Angus, United Kingdom
How to clear the error codes?
  • Posted 27 Feb 2017 05:09
  • By horvath_a
  • joined 23 Feb'17 - 1 message
  • Harghita, Romania
Your question on the code 522801-13 is the e-hydraulic valve needs calibrated.
  • Posted 26 Nov 2015 23:26
  • By BREWSKI
I deleted the error. Is working good now.
  • Posted 26 Nov 2015 21:03
  • By daniel_v
  • joined 24 Nov'15 - 6 messages
  • Tulcea, Romania
Does anybody knows how to reset the error 676-4.
  • Posted 24 Nov 2015 22:32
  • By daniel_v
  • Tulcea, Romania
I have changed the glow plugs. I clean the fuel filter and after that it runs perfect. But the error 676-4 is still prezent but the forklift is working well.
  • Posted 24 Nov 2015 22:31
  • By daniel_v
  • Tulcea, Romania
  • By daniel_v
  • Tulcea, Romania
I have a Hyster 5,0FT with error 676-4. It is starting and after 30 seconds is shuting down. Tomorrow I change all the glow plugs. Hope will work.
  • Posted 24 Nov 2015 02:24
  • By daniel_v
  • Tulcea, Romania
676-4 glow plug relay driver output reading low. 522762-4 switched battery voltage low IGN3. Check all the fuses, may have a bad relay.
  • Posted 18 Jul 2015 06:24
  • By BREWSKI
